Rachio Pro 3/4" Copper Wireless Flow Meter Installation Guide
Last Update:Oct 17 2023 6:38pm • Est. Read Time:Est. Read Time: 5 MINWondering what's going to happen now since you still have your Rachio Wireless Flow Meter although it's no longer manufactured by Rachio?
The good news is that we're still providing assistance for the installation, check this article!
Above: Wireless Flow Meter on 3/4-inch copper pipe with alternate fittings
Let’s get started!
Important
- Rachio recommends specific installation instructions based on your pipe size and material. Using any installation methods other than those recommended could damage the Wireless Flow Meter or void the warranty. Using glue of any kind will damage the flow meter.
- While installation times average 30 minutes, we recommend allowing 2 hours for completion.
- If you cannot complete any of the steps, we recommend a professional installation.
Make sure your system meets the installation requirements:
- Installation site must be within 300 feet of an installed and setup Rachio 3 Smart Sprinkler Controller.
- Backflow preventer and installation area must be above ground (recommended).
- System must have ¾-inch or 1-inch pipe made of either copper, PVC, PEX, or SDR9 Poly.
- For 1-inch PVC pipe, 1-inch copper or Poly pipe, and ¾-inch PVC pipe, you will need 14 inches of straight pipe between the backflow preventer and valve box.
- For ¾-inch copper or Poly pipe, you will need 16 inches of straight pipe between the backflow preventer and valve box.
Attention
The following Rachio Wireless Flow Meter installation instructions are intended only for irrigation systems with 3/4 inch copper pipe.
If your system uses a different pipe size and/or material, please visit rachio.com/flow for instructions tailored for your system.
What’s in the box
- Rachio Wireless Flow Meter
- Battery cover
- 4 screws
What you’ll need
Installation instructions are intended only for use with required fittings.
- Recommended manual pipe cutter (listed below)
- Required pipe transition
- Sandpaper or deburring tool
- Fine point permanent marker
- Stick ruler
- Phillips screwdriver
- Smartphone or tablet
Required parts and fittings for 3/4-inch copper alternate build
Required fittings:
- Three (3), 1-inch PVC-Lock Coupler
- Two (2), 3/4" Sharkbite Male Adapter
- Two (2), 1" x 3/4" PVC Spigot x Female Bushing
Required pipe transition:
- A 6-inch cut piece of 1-inch PVC pipe, (you may need to purchase a longer piece and cut it yourself). Note: For accurate flow measurement, there must be 6 inches of 1-inch pipe before the Flow Meter. Do not attempt to bypass adding the 1-inch transition pipe, as this piece is essential for proper installation.
Recommended pipe cutters:
- For copper pipe: 1 in. Copper Tubing Cutter. Do not use a hacksaw or PVC ratcheting pipe cutter.
Take Note
Important
Using installation methods other than those recommended in this manual could damage the Wireless Flow Meter or void the warranty.
Warning
Inserting your fingers into the Flow Meter or fittings can damage equipment or cause personal injury.
Using glue of any kind could damage the Rachio Flow Meter.
Need some help?
- Check out our Help Center
- Give us a call: 1 (855) 300-3569
- If you’re unable to complete any of the installation steps, we recommend a professional installation. To find a Rachio Pro, go here.
Are you a visual learner? You can preview the installation method in our video. Note that these instructions are specific to 1-inch copper pipe installations (original build; not alternate build described in these instructions) - fittings, tools, and pipe configuration will vary according to your system setup.
Installation Instructions
Step 1: Pair Flow Meter
- Open the Rachio app. From the "More" tab, select "Accessories," then add the Rachio Wireless Flow Meter. You will be guided through the pairing process and then prompted to continue installation using this digital manual.
Step 2: Turn water off
- Drain the system by running any two zones for one minute each using the Quick Run feature in the Rachio App.
Step 3a: Connect fittings
- Connect one 1-inch PVC lock fitting to one PVC bushing. Next, insert the male adapter Sharkbite into the bushing. Twist to ensure the three pieces are tightly connected.
- Repeat the step above with the remaining PVC bushing, male adapter Sharkbite, and one 1-inch PVC lock fitting. When completed, you will have two of the same configuration (lock fitting, bushing, male adapter).
- Important: Connect one configuration (lock fitting, bushing, male adapter) to the right side of the flow meter so the arrows on the flow meter point to the configuration. Use a twisting action until the flow meter is seated.
- Connect the remaining 1-inch PVC lock fitting to the opposite side of the flow meter. Use a twisting action to make sure the flow meter is seated, then insert the 6-inch transition pipe into the flow meter.
- Insert the opposite side of the transition pipe into the remaining lock fitting configuration (PVC lock fitting, bushing, male adapter).
Step 4: Measure and cut pipe
Instructions for cutting ¾-inch copper
- Identify 16 inches of continuous straight pipe between the backflow preventer and the valve box.
- Mark 2 inches after the start of continuous pipe (this is often after a joint); this will be the top cut.
- Mark 13 ½ inches after the first mark; this will be the bottom cut.
- Put a small X next to the first two marks.
- Mark 1 ⅛ inches above the top mark to indicate insertion depth.
- Mark 1 inch below the bottom mark to indicate insertion depth.
Accuracy is important here! Measure twice, cut once.
Step 5: Cut and clean pipe
- Make a clean, straight cut on the two innermost marks (denoted with X’s).
- First, cut the top innermost mark.
- Next, cut the bottom innermost mark.
- Do not cut the pipe on the outer insertion marks.
- Some water may leak out of the cut.
- Use the deburring tool or sandpaper to remove rough edges and debris inside and outside the pipe.
Step 6: Install the flow meter
- Important: Install so the arrows on the side and face of the Flow Meter are oriented with the direction of water flow. (Water flows towards the valve box; towards the ground.)
- Push the flow meter, fittings, and pipe together firmly while twisting the fittings to the insertion marks.
- All Rachio recommended fittings swivel 360˚, allowing for easy directional adjustment of the flow meter after installation.
Step 7: Turn water on
- Turn the water back on.
- Check installation site for leaks. If there is a leak, turn the water off and make sure the fittings are pushed up to the body of the flow meter and insertion marks. If the leak cannot be remedied, visit rachio.com/leak.
Step 8: Calibrate zones for leak detection
- To enable real-time leak detection, you must calibrate the Rachio Wireless Flow Meter. In the app’s "More" tab, select "Accessories," then select the Rachio Wireless Flow Meter. Follow the app instructions to calibrate.
Congrats, you did it!
